40 or 420 on youtube
Cletrac68
Post by Cletrac68 » Fri Jan 03, 2014 11:33 am
Post by Lavoy » Fri Jan 03, 2014 12:01 pm
This is part two to the post below.
Cletrac68
Post by Cletrac68 » Fri Jan 03, 2014 2:19 pm
Sorry - wrong page. My 420 was kinda tight when we brought it home. Put some PB blaster in spark plug holes - left it sit for a week. Used a pipe wrench to turn the front pump coupler to loosen it up. Also pulled valve cover to check for stuck valves. Compression check showed 70#'s. Put plugs, points and fresh fuel. Started up fine .....oil pressure is good. I guess I lucked out.
