Lavoy, Was in wrong port when I talked to you on the phone. That was low pressure port and that reading was normal. When hooked into port to check for 100 to 120 psi found she had 90. Added a shim to the two that were there and brought pressure up to 100. You said you like to run on the high end so now the question is how many shims can be put on valve. Maintenance manual does not say and the parts book says sold in bags of 10 with 9 used so that makes me think maybe three each valve is max.
Thank you, Doug Keith
JD1010 reverser pressures.
Keithfarm1
Users browsing this forum: No registered users and 213 guests
