MC battery door
sleepyhollow
MC battery door
Post by sleepyhollow » Thu Dec 12, 2013 1:06 pm
Hi, does anyone make the correct battery door for a MC or have a photo of an original so I can modify one? Thanks.
Post by Lavoy » Thu Dec 12, 2013 2:55 pm
The exact original is not made by anyone. I may have an NOS one left, or can get a new reproduction that I can explain to you how to make it work, and will not be any different from the outside vs original.
Howard Yoder
Post by Howard Yoder » Tue Dec 17, 2013 4:33 pm
Is the door you have Lavoy does it just have 2 holes that go on pins or does it hinge
Post by Lavoy » Tue Dec 17, 2013 5:35 pm
Pins that go in holes is what the 40 and 420 use. MC is supposed to be a two piece hinge setup that you can remove the door. Only thing available any more is a non-removable hinge door. You weld the hinge at 90 degrees, and put pins in place of the hinge bolts and mount it like the 40/420.
The NOS one I have is original MC.
Users browsing this forum: No registered users and 260 guests
