Stuck dowels on 831 loader / 1010 Crawler
430deere
Post by 430deere » Tue Oct 08, 2013 4:07 pm
I am trying to remove the 831 loader from my 1010C, to make the steering clutch job a bit easier. I am down to the dowel on the rear left side (not the very rear, but on the side) The one on the right hand side came out without much trouble. Does anyone have any tricks to removing these? I am following a JD Service Bulletin that describes how to remove the loader, as the Operator's and Service manuals do not show this.
I am also checking out the master pin, and it almost looks to me like someone has "tack-welded" the backside of each pin to the track. Any thoughts on removal? Simply grind off the welds and carry on? Does not look like there's a snap ring on it at all.
Any help would be great!
40U Orange (CJ 108)
320U Yellow
420T Yellow
420U Yellow
420W Orange
420W Yellow
430U Yellow (CJ 265)
730D STD ES
1010 ICD w/810 Loader & 50 Backhoe
3010 Industrial Wheel w/720 Loader (Gas)
3010 Industrial Wheel w/Ldr. (Gas)
430deere
Sorry - think it's an 810 loader.
Post by 430deere » Tue Oct 08, 2013 4:11 pm
810 loader
40U Orange (CJ 108)
320U Yellow
420T Yellow
420U Yellow
420W Orange
420W Yellow
730D STD ES
DukeofDeere
Post by DukeofDeere » Tue Oct 08, 2013 4:58 pm
II would grind off only the master pin if it is welded and replace it. The rest are so loose they chose to weld 'em in.
Duke
Gil
Post by Gil » Thu Oct 10, 2013 9:15 am
You might try oiling up the pin on the right hand side and replacing it. Then while it holds its share of the weight, try to remove the left hand side. Gil
Users browsing this forum: No registered users and 55 guests
