marc
Post
by marc » Wed Sep 04, 2013 5:21 am
got jd 350 crawler loader last year,worked great,put new chains,rollers,sproket.this year runs great but when you pull lever to turn left or right crawler stop moving forward and does not turn let go lever and push reverser to go in other direction it starts going forward but dont turn or move forward once lever is pull again.need help to determine problem thanks marc
Post
by jtrichard » Wed Sep 04, 2013 9:31 am
in reverse does it turn at all? under heavy load straight ahead what happens does it spin the tracks?
marc
Post
by marc » Wed Sep 04, 2013 10:13 am
it does not turn in reverse nor does it spin the track in forward will not push anything at all when blade down,but im able to get it to move with it up
marc
Post
by marc » Wed Sep 04, 2013 10:15 am
had the back end struck in pretty deep mud at camp.over tracks
Post
by jtrichard » Wed Sep 04, 2013 1:05 pm
looks like either your reverser has a pressure problem(hows the oil level?) OR both your steering clutches are slipping..... i would A(check oil) B do a complete ( BY THE BOOK) steering clutch/brake adjustment and see what that looks like and does then start looking at reverser is there a filter on reverser? if so when was it changed last?
Post
by jtrichard » Wed Sep 04, 2013 1:35 pm
there is a filter on the right side mid way of the reverser... JD# at15088 and gasket #t84543 napa crosses to a FIL1242 on the filter but that MAY not be right
rcs110
- 430 crawler
Post
by rcs110 » Wed Sep 04, 2013 3:37 pm
sounds like you got water inside the steering clutch , i did the same thing last year and it was water that took out the steering clutch. check to see if the drain plugs are in the bottom of the drives. thats where the water would enter.
1969 350 crawler
t4e3d
marc
Post
by marc » Thu Sep 05, 2013 5:22 am
is there a fix or do i have to take it all apart and install new steering clutches
marc
Post
by marc » Thu Sep 05, 2013 5:28 am
already change filter on reverser and oil level is right on only thing that i didnt do was to install new steering clutch maybe should had done that while it was all apart,guy i got it from said they were good,im new at this so took his word for it.now its 8 mile in bush at hunt camp,making working on it harder.
rcs110
- 430 crawler
Post
by rcs110 » Thu Sep 05, 2013 6:40 pm
I had to install new steering clutches and now it works great.
rcs110 on Sat Sep 14, 2013 11:56 am, edited 1 time in total.
1969 350 crawler
t4e3d
scremineagle
- 430 crawler
Post
by scremineagle » Sat Sep 14, 2013 7:15 am
was installing steering clutches a big job & what did they cost? think i may have same problem.
