79 JD 450c track tensioner adjustment?
450cgreenhorn
- 40C crawler
How do you adjust tracks on this machine? also I lost right steering control and believe linkage came apart under the seat/gas tank area how do I access linkage area to check? Everythings looks right and together all the way back to the fuel tank....tips, tricks, Pics????
450cgreenhorn
- 40C crawler
Hey there 450cgreenhorn, have you looked at the linkage that connects to the steering valve under the seat cushion? Did it stop turning to the right all of a sudden? Our 1977 450c stopped turning to the right also. when I opened the left steering housing inspection plug I got oil coming out and I can hear oil spraying. I think I have a hole in the pressure hose that delivers oil from the steering valve to the clutch pack. I only have this symptom in the left steering housing. The right is good. I will have to take the battery box, fuel tank, seat frame and hydraulic tank off to get access to the steering housing top covers. I know I don't have to take the hydraulic tank off for the left side, but I think I'm going to inspect the right hose anyway. What year is your 450c. My Technical manual number is TM1102. Check your year and model before ordering. I paid like $99 for a downloadable copy from johndeere.com.
450cgreenhorn
- 40C crawler
450cgreenhorn
- 40C crawler
450cgreenhorn
- 40C crawler
450c greaser
well guys, I bought a manual, adjusted the tracks and popped the seat up and off to check out steering linkage(s)....well simple fix, $2 roll pin broke in the right steering brake pivot linkage, little bit of a pain to get to but we got'er. thanks for the guidance....
Users browsing this forum: No registered users and 185 guests
