440 ICD Hydreco pump
Hi all need to replace 6 spline drive shaft and coupling. Have pump off bracket but still connected to hoses cant find spring pin to get coupling off pump shaft. and what way is easiest to get drive coupling off lower motor pully drop skid pan, pull radiator or pull pump hoses off How to drain hyd tank. drive spline appears 2 diameters need this and coupling and need also rubber bushings on bolts for drive coupling (4) Any and all help is appreciated jim 781 361 3731
Users browsing this forum: No registered users and 200 guests
