1966 john deere lawn crawler
- mapaduke@yahoo.com
nothing crawles like a deere
- Willyr
you will want some grousers on that if you try to work it.
former owner of a 1956 420c
Anderw I used Go Kart hydraulic master cylinders and calipers the only machining done was to the hubs they were cut down so the Go Kart rotors can be slid on with a square shoulder then welding them on.
willyr For now it seems to work ok and turns real nice I have only 2 hrs run time on it but I think I may need to add grousers to keep the pads from bending This one is just a toy. I want to make one out of a 140 h3 paint it industrial yellow and a 6 way blade maybe even a ripper on the back?
- Willyr
Your going to find as soon as you have a blade on there. The first little bit of earth you try to move, all it will do is spin those cute plates.
I had a home made dozer similar to the pic below. You could cut the crown out of a drive way with a 1/4 inch of grouser and a 8 hp briggs and stratton.
- Willyr
I am curious what you used for your chain for the crawler tho?
