420C Parts Needed
tobaccoman
420C Parts Needed
Post by tobaccoman » Sat Jun 03, 2006 8:44 pm
Need left side fender brackets and complete battery box. I also need the complete transmission shifter. (4 speed non gated). Also would like to buy original headlights and headlight guards. Thanks, Jimmy
Post by Lavoy » Sun Jun 04, 2006 10:47 am
Battery parts are all available new, that is no problem. There is only one bracket at the rear of the fender, I may have a used one. I should have a shifter, need to know serial number. Do you want actual original headlights, or correct repros? I have a pair of guards on hand.
tobaccoman
Headlights
Post by tobaccoman » Sun Jun 04, 2006 11:58 pm
Lavoy, Repro's would be fine with me. How much for the fender bracket? I will try to get serial number to you later this evening. Thanks, Jimmy
tobaccoman
Headlight guards
Post by tobaccoman » Sun Jun 04, 2006 11:59 pm
Sorry I forgot to ask how much for the headlight guards.
Post by Lavoy » Mon Jun 05, 2006 7:52 am
Guards are $100 for the pair, repro headlights are $35/each. I will have to check on the bracket to see if I even have one.
tobaccoman
Serial number
Post by tobaccoman » Mon Jun 05, 2006 9:58 pm
Lavoy, I have the serial number. It is 420C 84225. I think this is a all green crawler, but I'm not sure maybe you can let me know. Please let me know if you have the complete transmission shifter for this serial number and the price. You can let me know after you check on the fender bracket. That way I could possibly get everything at one time.
Thanks, Jimmy
Post by Lavoy » Tue Jun 06, 2006 9:11 am
Jimmy,
Correct, that is an all green. I should have the shifter, may not have it here. Shoot me an e-mail and I will get back to you, maybe not until the weekend.
