JD 350C aftermarket vs OEM
sullyt28
Post by sullyt28 » Mon Jun 10, 2013 6:39 pm
Need to purchase a brake band for this dozer. From the dealer its over $1000 aftermarket it is $250. Anyone have any experience with aftermarket brake bands ? Any suggestions where to purchase from a reliable source ?
Appreciate any feedback.
Sully
Barrie, ON
rcs110
Post by rcs110 » Mon Jun 10, 2013 8:27 pm
I would check with Lavoy.
1969 350 crawler
t4e3d
Post by jtrichard » Mon Jun 10, 2013 9:55 pm
you should be able to get yours relined for about $100/150 thats if there is any brake shops near you ... you can also look at some posts on 2010 clutch/brake rebuilds that the guys did them selfs the main difference is 2010 is dry yours is a wet brake
sullyt28
Post by sullyt28 » Tue Jun 11, 2013 4:40 am
I was hoping to avoid the downtime and spend the few extra bucks so i can put it back together vs waiting to have it re-lined and loose some momentum in the project.
If i can't find a creditable place to purchase from than that is what I will most likely do.
Sully
Barrie, ON
Post by Lavoy » Tue Jun 11, 2013 7:26 am
With any product there can be problems, but that should be the exception, not the norm, and if not, then the retailers should stop handling that product. Way back I had some trouble with the two cylinder bands when they were first produced, but some manufacturing changes, and no more problems. I have sold hundreds of aftermarket bands with maybe 10 failures, and some of them might have been operator induced.
