1010 crawler rpm setting
When I am using my backhoe, what RPM should I set the throttle at?
Maximum hoe usage
These old hoes can get fairly loose, so probably as much RPM as you can handle. Well, I've never actually ran a hoe on a 1010. My dad has 3 of the old day 1 attachments piled up that he won't let me sell. Guess I'm going to have to assembly one and see how they dig.
We set our reliefs high enough so we're just able to move the crawler around on our 350's. Something to consider vs. running your engine at a higher RPMs. You may want to put a gauge on if your not sure how to make this adjustment. We normally back off on the pressure and then turn it up slowly until we are happy with the operation.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Users browsing this forum: No registered users and 253 guests
