mc rails and pads
lennythemonster
mc rails and pads
will the rails and pads off of a 40 fit on an mc
Yes, as long as they are 28 links long.
Re: mc rails and pads
I do believe that the width of the pads need to be the same as what you have or you will need the correct drive sprockets.lennythemonster wrote:will the rails and pads off of a 40 fit on an mc
1949 MC
"If it ain't broke, don't fix it"
Pad width shouldn't matter unless you are narrowed up, or might have blade clearance issues. Look at all the clearances to the pads you have now, and that will give you an idea.
