440icd front mount hydraulic
440icd
Post by 440icd » Tue May 23, 2006 2:20 pm
Lavoy, I may be looking for another flange that bolts to the crank that has the splines for the hydraulic pump.
Do you have a good one?
Will anything else bolt up there?
The one I have is a 1 inch 6 spline hole.
I have a different pump on it now with a different spline on it. Kind of a baster type setup. Had to make a coupling last year for it and yesterday spun the splines right out of it again.
I think that there was, and is an alignment issue. How the heck do you check alignment ?
I was thinking of going to a different spline setup, one a little more standard.
Any Ideas?
Scott in wa.
Post by Lavoy » Tue May 23, 2006 2:45 pm
I don't have anything left. If you can find it, a flex coupling might be the way to go, it would eliminate some of the alighmet issues.
lavoy
440icd
Coupling drive front mount to crank
Post by 440icd » Fri May 26, 2006 10:27 am
Just thought I'd give an update on the front coupling drive system I have on my 440 loader, for the hydraulic pump.
I had set it up last year, with a new pump that had a 7/8 13 spline, and the old drive hub had a 1x6 spline. I bought some parts from the local drive line outfit to do that, with a small amount of machining.
It lasted about a year, so I was on a hunt for a better set up.
I found out that a brand new drive hub, After market, that bolts up to my crank, that has a 7/8 13 spline was $32 bucks, wow brand new, no more 1x6 spline…. ya....
Then bought a used, looks new, 7/8 13 oem John Deere splined shaft that appears to be hardened, for $80 bucks then a 7/8 13 splined sleeve, again a used John Deere part, but looks new.
These were installed on newer model dozers, I believe a 350, but they appear to bolt up, will install this weekend. Found them at a place called County Line Equipment in Fife Wa. ( Oh ya I also got a failure to obey a traffic device on the way home for 101 bucks, I guess you could add that to the total, crap I messed up there.
Just thought Id post up and maybe save someone some time and go straight for the 350 parts instead of the old 1 x 6 spline 440 stuff , and all the unhardened driveline hardware.
Total of about 166 bucks, plus the 101 dolor ticket :( I think I spent about half that on the stuff I put together last year that finally gave up.
:lol:
Scott in wa.
sam
Post by sam » Sat Jul 01, 2006 10:22 am
Hello, Scott
I was wondering where you found the 13 spline flange that bolted to your crank? The part you said was aftermarket. Was it as short as the old 6 spline?
Sam
440icd
spline
Post by 440icd » Mon Jul 10, 2006 1:25 pm
Hi Sam,
I got that stuff from County line Equipment in fife wa.
Yes I think it was as short.
I believe it was for a 350.
It bolted right up, with no problem. It was pretty inexpensive.
The hardened shaft I had to buy was more expensive, it was splined the full length, and yes it was to long, I have to abrasive cut it to length.
Might be because Iam using a different pump don't know.
But the old shaft was very short; This one that I bought used was way to long. it even had a hole in it for a pin to keep it in the sleeve in position.
Sorry it took so long to get back to you, I didn't notice your post.
Scott in wa.
sam
Post by sam » Mon Jul 10, 2006 4:34 pm
Scott, I have county lines number and plan to call them. I have a pump off of a 350 loader with all the shafts, couplers but the flange will not work. Is it possible that the part you have was for a detorit power unit on a differant application?
Sam
440icd
flange
Post by 440icd » Tue Jul 11, 2006 6:07 am
I don't think so,
Talk to the john deere guy, tell him what you have, he can tell you what will work. Don't know if the 350 loader is different
thanks
scott
Scott in wa.
Users browsing this forum: Google [Bot] and 373 guests
