420c hydraulic cylinder seals
Kws346
Post by Kws346 » Tue Apr 16, 2013 4:55 pm
I am needing to replace the top seal on the hydraulic cylinders for the blade on my 420c. Does anyone know a part number for this seal and where to purchase it at? Are these seals easy to replace? I have never replaced these before. I really appreciate the information that has been provided on my other questions while getting this dozer back together.
Post by Lavoy » Tue Apr 16, 2013 10:02 pm
No way to know without knowing the specifics of the blade, factory or non, which model number, original cylinder, etc.
Kws346
Post by Kws346 » Sat Apr 27, 2013 11:43 am
Do you know where I can get a CR12389 oil seal for this cylinder? I tore it apart today, but the part stores say that this seal is no longer manufactured.
Post by jtrichard » Sat Apr 27, 2013 2:58 pm
if lavoy does not have it ... napa nos 12379 ....it is the wiper seal? ID 1.25 OD 1.878 thick .25
Kws346
Post by Kws346 » Sat Apr 27, 2013 3:15 pm
Gil
Post by Gil » Sat Apr 27, 2013 6:54 pm
The part you asked about is a wiper seal, primarily used to keep dirt out of the cylinder, not to keep oil in. If your cylinder is leaking it is from a seal or packing within the cylinder. Depending on the design, you have to remove a threaded fitting, spring clip, etc. to remove the end of the cylinder. If you know the model or at least the maker of your bulldozer blade, like Lavoy said, someone may be able to better help you. Alternatively a photograph of the end of the cylinder would help. Gil
Users browsing this forum: No registered users and 166 guests
