2010 Gas Distributor change
Hello all! Has anyone changed out a prestolite dist. for a pertronix electronic dist. my org. prestolite part # IBT4101 R 7 G ccw rotation the pertronix part # D41-05A complete and they recommend their coil. just the replacement for the points is a #1542 or #1543 plus their coil. A little more backround info, I have switched over to a 12 volt neg ground replaced gen. with a GM style Alt. wired a charge light with diode Ballast resistor for my points A battery shut off switch all new connectors for my key and light switch .All in all a rewire job complete with fusable links . With all this done as well as the linkage to the govener rod which when running ok prior seemed to react properly. Any additional info on the change would be helpful.Thank you! JDjoePA
DIST CHANGE
I HAVE A CASE UNLOADER AND MY DIST SHAFT HAD PITS WHERE THE POINT RUBBING BLOCK RIDES IT WAS CAUSING THE POINTS TO WEAR OUT VERY FAST I PUT IN A PERTRONICES KIT AND MY MACHINE RUN BETTER THAN THE TEN YEARS BEFORE STARTS RIGHT UP AND RUNS STRONG WITH OUT HAVE TO KEEP RESETING POINTS THE KIT WAS 90.00 DOLLARS GOOD LUCK PS AFTER ABOUT 3 WEEKS OF TRYING TO FIND A DIST WITH NO LUCK I DID THIS BEST THING I EVER INSTALLED ON MY MACHINE
