350 transmission
rcs110
350 transmission
Post by rcs110 » Sun Apr 07, 2013 6:43 pm
has any rebuilt a transmission on a 350 , after sitting all winter I did some work with the 350 this weekend and started to hear a noise in reverse the 350 stopped and i could not sift it out of gear,
it has a reverser and it was making a winding noise in when in reverse,
while moving forward it stopped, unable to sift it in to neutral on the transmission gear sift , I did have to add oil to transmission and then I was able to get it moving again It was stuck on a hill when i added the oil.
the 350 after that worked fine for about one hour then started to here like a bearing noise it got stuck again and after shifting it back and fourth it started to move so i parked it and now thinking i broke something in the transmission. any one have any ideas?? :cry:
1969 350 crawler
t4e3d
KenP
Post by KenP » Mon Apr 08, 2013 4:07 am
deleted
rcs110
update took machine apart here are some pictures
Post by rcs110 » Fri Apr 26, 2013 6:54 pm
1969 350 crawler
t4e3d
rcs110
Post by rcs110 » Fri Apr 26, 2013 7:01 pm
1969 350 crawler
t4e3d
rcs110
Post by rcs110 » Fri Apr 26, 2013 7:03 pm
1969 350 crawler
t4e3d
rcs110
Post by rcs110 » Fri Apr 26, 2013 7:32 pm
well after taking it apart it looks like I will have to get the following parts :
1. transmission input shaft with new bearings( the rear bearings broke apart took a few gears with it. t23653 shaft & jd8187 bearing &jd8225 bearing cup
2.2nd and reverse speed gear t16326
plus a few small other things that I found wrong that need to be fix.
so far it took 6 hours to take apart. the only thing left is to remove the transmission form the machine and that I need help with, so I to wait til May to get this done.
will post more pictures when that happens.
1969 350 crawler
t4e3d
rcs110
Post by rcs110 » Fri Apr 26, 2013 7:36 pm
1969 350 crawler
t4e3d
jdlou
Post by jdlou » Fri Apr 26, 2013 7:44 pm
Thanks for the upclose and personal pictures. It gives all of us something to refer to in the future. Good Luck on the rebuild!!! :) jdlou
:)jdlou(:
rcs110
update
Post by rcs110 » Sat May 18, 2013 10:56 pm
well just took off the transmission
now its time to rebuild it.
Image[/img]
1969 350 crawler
t4e3d
Post by Lavoy » Sun May 19, 2013 11:14 am
I can get quite a few new 350 trans parts if you need them.
rcs110
some more pictures of damage from what the bearing did
Post by rcs110 » Tue May 21, 2013 6:53 pm
1969 350 crawler
t4e3d
rcs110
rebult transmission
Post by rcs110 » Mon Jul 22, 2013 9:48 pm
well I got it done with the help from Lavoy finding and shipping me all the parts I needed. two days to put it back together and finding out one of the drives was not happy with thew brake band :( I must say I got pretty good in removing the drives ,and putting them back on. here are some pictures of it . its working fine now and once again thanks Lavoy with all your help with the parts.
1969 350 crawler
t4e3d
Post by Lavoy » Mon Jul 22, 2013 11:04 pm
Man, what a lot of work, but gratifying once it is all back together.
