JD 1010 5 roll with winch and outside blade for sale
Post by Paul Buhler » Wed Apr 03, 2013 5:01 pm
Hi:
I was traveling through Meriden, NH today and found this dozer for sale. There was no one around, so I didn't hear it run or see it move, but it looks like a sound machine. In particular, the undercarriage is in very good shape. Good meat on the sprockets, and the rails look good and the pins and bushings appear to have been replaced based on the track length. One track needs to be pumped up - poor adjuster seal? The Gearmatic winch and control are there; the brake side cover has a small missing piece, but it shouldn't affect operations- the cable is in good shape. The blade has a reasonably new cutting edge. The machine seems tight with only a few minor fuel and oil weeps. No puddles on the ground:-). The hour meter had useless numbers on it, and I forgot to get a picture of the serial number - sorry.
I'm sharing this info just because... I have no interest in this machine. You'll need to contact the owner and do your own due diligence. The contact info is in one of the pictures. Good luck. Paul
http://s460.photobucket.com/user/pbuhle ... zer?page=1
