430C needs a water pump, etc.
Lavoy; I have a 430C and I need a water pump and a backplate for same. And a thermastat. Also the tracks are loose, and no adjustment left. Can you give me a quote on a track job? Thanks Bobmn
New water pump is about $130. The first back plates I had made I am not happy with cosmetically, but they are functionally fine.
Rebushing normally runs $950 parts and labor, a little higher if I have to do a lot of link repair, or if you need more links.
Thermostats are less than $10, don't remember for sure.
