1970 JD450 crawler injector pump fuel shutoff
markmc60
Post by markmc60 » Sun Mar 24, 2013 7:38 am
my 70 model JD450 will not shutoff immediatleywhen I turn off the key(or pull the power connector at the pump).
if I tap on the side of the pump or just wait it will eventually closed the solenoid and die. I know the solenoid is sticking, I am just not sure how to fix it.
any suggestions on how to replace the shutoff solenoid?
CatD8RII
Post by CatD8RII » Sun Mar 24, 2013 11:25 am
Please view this thread, it shows your solenoid in detail.
http://www.jdcrawlers.com/messageboard/ ... t=solenoid
vestor_guy
Post by vestor_guy » Sun Mar 24, 2013 11:38 am
The replacement parts are no longer available for that model. I would suggest removing the solenoid, plunger and spring and make sure they are clean and re-install. It is obviously working to open but the spring is not seating the plunger when the solenoid is unpowered.
markmc60
Post by markmc60 » Sun Mar 24, 2013 6:36 pm
as soon as I posted the picture I realised that it most likely unscrewed, I will give it a try first chance I get.
thanks for the links and information.
KenP
Post by KenP » Sun Mar 24, 2013 7:16 pm
deleted
markmc60
Post by markmc60 » Tue Mar 26, 2013 7:57 am
yep, I know that, the strike marks are from the previous owner, but thanks for your concern.
markmc60
After market solution
Post by markmc60 » Fri May 27, 2016 5:55 am
There is an aftermarket solution. I bought it. About $100. Complete replacement of solenoid. Works perfect. Everytime
450 dozer
