2010/350
meadova
2010/350
Post by meadova » Thu May 18, 2006 8:27 pm
Have an offer to buy a 2010 crawler dozer cheap, already own a 350. Wondering if any of the major parts will interchange. 2010 tracks and tensioners are worn out it does have a winch. 64 model I think. 350 is a 68 model.
2010OWNER
Post by 2010OWNER » Wed May 24, 2006 10:47 pm
Medova,
Tracks may interchange. AT 17270 is the part number for the chain; check your 350 parts book to see if they are the same. (Chain is 39 links long on the 2010.) Winch should be interchangeable.
Don't know about bottom rollers or top idlers.
Everything else is different.
Brian
Post by Lavoy » Wed May 24, 2006 10:50 pm
2010 after 42,000 uses the same chain as 350, just longer. Rollers should bolt up, don't think upper idler will. I don't think the winch will bolt up, back cover on trans is different.
