squealing when dozer gets warm after about 2hrs. usage
we replaced the clutch and brake bands but when we use the dozer now after about 2hrs of use the left side steering squeals if you let it cool down and readjust it its fine until it runs and gets warms again are new clutches this hard to keep in adjustment and if not whats wrong? should have said its a jd 450B
you should not have to readjust ..maybe after a month or two you might want to check the adjustments i doubt it is the clutch sounds more like the brake band is to tight or a bearing is tying up any oil in the finals?
Users browsing this forum: Google Adsense [Bot] and 295 guests
