450B Left Steering Clutch Removal
harvesthill
Post by harvesthill » Sun Mar 03, 2013 1:02 pm
Okays guys her it goes,
As most of you probably have done, I am trying to remove the steering clutch out of my dozer. It is totally locked up. The dozer is up in the air and both tracks are off. I need to get the clutch pack spun around to get the set screw out to remove the final drive smaller gear and shaft. I have tried many thing to bring it around and it still wont turn. I thought by taking both track off it would be easier to turn but no luck. Anyone know how to get this old girl to turn that cluch pack around and get it out? Oh yeah I have the whole operator station off and the brakes on that side.
Thanks in advance for any information,
John
JWB Contracting
Turning the axle
Post by JWB Contracting » Sun Mar 03, 2013 2:00 pm
We normally split the offending track, have one guy pull the other steering clutch handle back and the use a large crow bar between the sprocket and track frame to spin it over. If you've pulled the sprocket, you can put a couple sprocket bolts back in and put your bar between them to rotate.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
harvesthill
Post by harvesthill » Sun Mar 03, 2013 2:35 pm
Okay thanks got it finally. Now just have to pull the inner shaft out. Anyone know the thread size on the inner shaft? I have been told it's a 3/8 x 16 pitch.
