My dist needs to be rebuilt. The bushing is worn and is very hard to gap the points. The shaft might even be worn. I also noticed the fly weights are rusted tight. I would also need points, condenser, breaker plate gasket, cap, rotor and wires.
Do you have assembled rebuilds available or do I have to buy the parts and do it myself?
1958 420c Distributor
- joeturner1977
- 430 crawler
-Joe
1958 420c w/mc60 blade
Rebuilts are not available any more that I have found. Only thing I might have is a good used one. If yours is rebuildable, that might be your best option.
Reg Taylor
420 Distributor
I had the same problem as you and found a rebuilt dist. at Restoration Supply Tractor Parts at www.tractorpart.com. I purchased one from them and it was completely rebuilt with bushings, points, cond., cap. Good service and good product. They also buy rebuild cores. Hope this helps.
1956 JD 420C with Gearmatic model JD40 blade & 8A winch, 1935 Caterpillar 22, 1948 Ford 8N
- joeturner1977
- 430 crawler
Tractor parts has this for $200.
"John Deere M, MT, 40, 320, 330, 420, 430, 440G Rebuilt distributor with points ($30.00 credit when a good core is returned)"
I think this the way I am going to go. I dont think I could buy all the parts for less. Esspecially with rusted tight flyweights and advance springs.
Lavoy, How much for a good used one?
Thanks for the tips...
-Joe
Good used dist is $75 when I have them, not sure what I have left, but can check.
Users browsing this forum: No registered users and 65 guests
