12v back to 6v what a mistake
ratskinner
Post by ratskinner » Wed Feb 20, 2013 7:26 pm
My 40c was 12 v when I got it and when I say 12v i mean none of the 6v stuff worked and the last owner put a 12v battery in it .So I repaired all the 6v stuff and now when it get below 30deg outside the 6v battery will not turn it over fast anough to start it.But when its warm out it will start so now when cold out i have to put a 12v battery in it to start it .
So what do i need to do to fix this problem .
hydrogeo
Post by hydrogeo » Wed Feb 20, 2013 7:59 pm
You have something going on. My 40c sat for a month, and it fired right up this weekend after another sub zero night. If your batter is good and all the connections are clean I would suspect the starter got hurt when the system was 12v.
Post by Lavoy » Wed Feb 20, 2013 8:06 pm
Rebuild the starter, check all connections, 650CCA or higher battery, #1 or better cables. Doing this I have started more than I can remember at colder temps than that.
Willyr
Post by Willyr » Thu Feb 21, 2013 6:44 am
I must agree with the rest. That 6 volt should wind right over. Here is my 420 when it was only 10 degrees here in Maine on 6 volt.
https://www.youtube.com/watch?v=uz4sAynD2mo
former owner of a 1956 420c
bmace
Post by bmace » Thu Feb 21, 2013 7:34 am
you might try putting a battery trickler on the 6 volt and let it recharge to full capacity for a couple two or three days. Once it is fully recharged you shouldn't have a problem. I run all 6 volts on four different crawlers and have found this to be a problem if only running for a short time in real cold weather
Howard Yoder
Post by Howard Yoder » Sun Feb 24, 2013 1:16 pm
also are you pushing the clutch in when you try to start it heavy tranny oil can really make it turn over hard in cold wheather
