440ICD air leak????????????????????????
Post by Lavoy » Thu Feb 14, 2013 7:09 pm
Okay, maybe I am dreaming, but I swear that when I had the crawler running in the shop and sprayed some brake cleaner on the blower side of the engine, it seemed to pick up just slightly. On a gas engine, obviously an air leak, but what the heck would it be on a diesel? I can't find any obvious reasons, and was not spraying around the intake elbow, although tried it later with no change.
Post by jtrichard » Thu Feb 14, 2013 7:32 pm
any air leaks past the blower would be pushing air out not sucking in so the only way that i know of would be you must have gotten some near the intake or you need someone to wake you up :wink: :wink:
DukeofDeere
Post by DukeofDeere » Thu Feb 14, 2013 8:16 pm
Maybe leaned on the throttle linkage? :shock:
Post by Lavoy » Thu Feb 14, 2013 10:05 pm
Yeah I know, but I was able to repeat it a couple times, that is what has me stumped. I had the intake elbow off, cleaned it up, and put it back on with gasket sealant so it can't be leaking.
Post by jtrichard » Thu Feb 14, 2013 11:29 pm
probably just some vapor got to the intake?
pop pop
Post by pop pop » Fri Feb 15, 2013 8:59 am
you know, that cold dakota air and spraying that housing might have condensed the air enough to make it do that....maybe formed ice crystals inside? i dont know,,, you got me thinking outside of the box.
Post by Lavoy » Fri Feb 15, 2013 3:10 pm
Had it in the shop while doing it, so not a cold issue. I was wondering if it could be vapor even though the top of the air cleaner is a ways away. I think I am going to check the steel pipe and the two elbows a little closer just in case.
If the new elbow samples I have coming work, I will replace both of them regardless.
gregjo1948
440 ICD air leak
Post by gregjo1948 » Sun Feb 17, 2013 7:54 am
How volatile is brake cleaner? Aerosol propellant is explosive and may be finding a path to your intake. I would think the slightest explosive mist around the intake of an engine with a blower, would be forced into the engine and creating a change in rpm. gregjo1948
Post by Lavoy » Sun Feb 17, 2013 11:57 am
Depends on the brake cleaner, but the stuff I am using is probably about like carb cleaner. I thought about that too, but I was spraying about 3 feet from the air cleaner intake in a shop with no breeze, so had ruled that out. Plus, it only occurred when spraying directly in the area of the blower, not any place else.
Labrador_tractor
Post by Labrador_tractor » Sun Feb 17, 2013 4:19 pm
At a garage I used to work in we regularly substituted brake cleaner for either, mostly trying to get them hateful mercedies benz engines to pick up there fuel after a service. we found the brake less sharp then either for the engine to run on, still had that distinctive sound of a diesel on either but much less harsh.
Scottyb
Post by Scottyb » Sun Feb 17, 2013 6:32 pm
My brother, who was a wrecker/salvage/dealer of motorcycles and sleds for most of his life, suggested to me that to check the crank seals on sleds spray a little either near the pulley and if the engine picks up a little they are leaking. Perhaps you have a seal, gasket or something similar happening.??
backhoe attachment.
Users browsing this forum: No registered users and 41 guests
