I have a 350C with winch problems. Where can I get winch clutch and brake parts other than JD? They are expensive there and they do not seem to have all the partrs I need. Any ideas.
JD 350C Winch
I may be able to get brake bands, but not sure.
- 40C crawler
Thanks, I think the brake band is ok. I seem to have a pressure problem. I get only about 300psi at the check port. I can not find any leeks on the brake side. I screwed the relief valve screw in as far as it will go and no luck. I looked in the service manual and I see something called a ball connector and I find it in the parts book but what does it do. The part number I think it is AT29070. Could it be my problem? Any ideas??? Thanks Very Much!!
Don
Don
Users browsing this forum: No registered users and 193 guests
