Detroit injector question
Post by Lavoy » Tue Feb 05, 2013 8:07 pm
After all these years, I finally find myself with a 440ICD, got it in the shop right now fixing on various items. It starts hard, pretty much like all of them, but tends to miss on one hole for just a few seconds at start up, then smoothes right out. Figuring one injector is hanging up, or getting bad, so looking at putting injectors in it. I have never done it before, how much of a job is it? Not worried about the R & R portion, just setting after they are installed. Lost my manual some how, won't have new ones til end of the week.
Also, assuming the engine still has S series pistons, should I put S series injectors back in, or switch to N series?
Post by jtrichard » Tue Feb 05, 2013 8:35 pm
setting the rack is not that bad i have a 6V53 hardest part is setting the high rpm (as is always said on here GET the book it really is simple with it).......when setting the high end it sounds like its gonna blow any minute being 2 stroke it sounds like its turning twice the rpm that it is.... the 6V53'S top end is 2850 sounds like 5700 RPM stand next to that and turn a screw while someone else is watching the tach and pointing up, up, up, :shock:
scampr
Post by scampr » Tue Feb 05, 2013 8:37 pm
If someone cant help you soon and i can figure out how i will try to copy it from the service book and email it... but will take me a while to figure it out
scampr 440icd, 350B, 47 Farmall H, 55 Farmall cub and ashamed to have a Kabota too
scampr
Post by scampr » Tue Feb 05, 2013 8:49 pm
Are you just looking for torque specs? clamp nuts 20-25ft lbs,,fuel lines 12-15 ft lbs and rocker are brackets are 50-55 ft lbs
Post by Lavoy » Wed Feb 06, 2013 8:10 am
Thanks for the replies, Ben sent me the manual, and I talked to a local guy that is a two stroke wiz. He is going to stop in next time he is in town and take a look at it. By the time I am done with finals and who knows what else, he will probably have been here.
Gil
Post by Gil » Wed Feb 06, 2013 10:57 am
I adjusted the governor using a cheap electronic laser tachometer I bought on eBay. I set the low idle at 785 rpm and high speed idle at 1910 rpm which seemed to work best for my machine. Gil
Post by JD440ICD2006 » Wed Feb 06, 2013 1:45 pm
You know what they say about opinions and advice? LOL
I would stay with S 35 if the pistons are S. No way to actually know which they are unless the head is pulled or you know the guy that rebuilt it.
If it starts real hard but the compression is still decent, my bet is they are S pistons.
Replacing injectors is not a big deal. DD has them rebuilt (core trade) for a resonable price.
They do have to be timed properly and that requires a little tool from DD.
At 40 degrees, my 2-53 with N kit will white smoke immediately and crank in a few revolutions.
About 55 degrees and above, you just need to look at the ingition key real hard and it will start.
Post by Lavoy » Wed Feb 06, 2013 5:11 pm
In the shop at 60 degrees it starts pretty good, only worry is a real short term hiccup on one cylinder, but hit the throttle and it disappears instantly, same thing when warm. I think I will let my guy set everything correctly and see how it acts. If it still bothers, I will put injectors in later, hit some major snags today on this crawler, so way too many other problems to worry about injectors now.
Labrador_tractor
Post by Labrador_tractor » Thu Feb 07, 2013 1:45 am
A buddy of mine has a 2-53 in a welding machine , his does the same thing , starts like a camp but one cylinder hesitates and takes a second or two to pick up. he rebuilt the engine in it when he got it and he's after changing the injector's , lift pump etc with no luck on it firing on 2 cyl's on start up. he just learned to live with it.
tuney443
Post by tuney443 » Mon Mar 11, 2013 10:53 am
Must be a 2/53 gene pool thing as mine also does this--will start up a little rough,then I'm assuming the other cylinder kicks in sort of like a turbo sound and after maybe 15-20 seconds she's running like a LOUD putty cat.
Found the skull to the mastodon in Hyde Park, youngest one ever found so far in the world in 2000.
JD35D midi exc.
JD410G TLB
JD450D Dozer
2 JD 440 track loaders
JD 420 track loader
JD 450C track loader
