return to dig
return to dig
the return to dig control on mt 450c track loader does not work, the test light shows juice at the switch on the boom, what else should i check, thanks
You will need to check your wiring all the way through from the switch. Make sure you are getting 12 volts through the switch all the way to the solenoid. The solenoid will be on the control valve. It will also need to be checked to see if it is functioning properly.
