JD 350 injector pump upgrade
eppeljd350
Post by eppeljd350 » Tue Jan 29, 2013 3:54 pm
Have 1970 jd350 with CBC pump (ouch) well quit working lost all power and now will not even start. New fuel / fuel filters/ transfer pump/ still will not fire. Good compression. line brings fuel to pump. Well I found a JB pump conversion kit and have gotten it. Now where I need help. Does anyone have or know where I can find a rebuildable pump and I also need the pump drive shaft or info about the drive i.e. is it the same as a regular drive? thanks
KenP
Post by KenP » Tue Jan 29, 2013 5:06 pm
deleted
eppeljd350
Post by eppeljd350 » Wed Jan 30, 2013 10:33 am
Why ouch cause of the Roosa pumps they are some of the most problematic. I currently have all the part numbers Thanks. I was hoping some one had an old shaft that i could reverse engineer. I would also like to get a jb series pump because I can get rebuild parts cheap. thanks again
Users browsing this forum: Google [Bot] and 34 guests
