1010 or 2010 Loader up for Auction - Make Bid
Pammark
Post by Pammark » Sat Jan 19, 2013 10:43 am
I hate to see a nice option cut up for scrap iron. This is the loader unit that will fit a 1010 or 2010 dozer. It is model 810-820 s/n 1543.
I have a 2010 loader and my model is a 820. It lookes the same. My bucket size is one cuyd.
All the hydraulic hoses are there but the return lines are rotted. There is no hydraulic pump to power it. The pump normally fits on the back PTO of the dozer. The hyd cylinders look good, but you are buying this AS IS.
The bottom mount brackets are there. The rear has the weight attachment and bolts right to the rear axle.
The reservior looks OK with the internal filters. I am not sure of the internal filter condition.
The control valve is free and not rusted tight.The front bucket has seen some use and the teeth are fair in quality.
This unit is located at a consignment auction in Ohio that will go on the auction block Jan 31 (thur). I will bid for you. I do not own this unit, just trying to save it from scrap iron.
If I get the winning bid, I will add 20% for my services to bid on it and move to my farm 20 miles away. I have a way to load it from there on your trailer. Then you can come later to pick it up at zip code 43040. Free outside storage at my farm for a resonable amount of time.
I will expect full payment within 14 days of the sale. There are NO RETURNS on this.
If you are interested, send me a personal message as to your highest bid for the loader, not including my 20%. I will do my best to get it for less. The highest bidder limit to me with have the first chance for the unit. If they back out, I will offer this to the next in line. I will notify the highest bidder by personal message the day before the sale that you might be the proud owner of the loader the next day.
Feel free to ask questions. The deadline for bids is midnight Jan 29 (tuesday)
Mark
JD 2010 Crawler with Loader
Post by jtrichard » Sat Jan 19, 2013 11:30 am
its off of a 2010 so it should be an 820 the 810 for the 1010 i believe is a smaller unit
Pammark
Model #
Post by Pammark » Sat Jan 19, 2013 1:06 pm
The unit is model 810-820. I guess that means it wil fit both the 2010 and 1010. You be the judge.
Mark
Post by jtrichard » Sat Jan 19, 2013 5:35 pm
i did some parts searching the main frame,loader arms,and rams are the same on 1010/2010 the bucket on the 1010 is 3/4 yard and 1 yard on the 2010 the rear brackets that bolt to the rear cross-member to the main frame are different and the rear most brackets are different on 1010 vs 2010 the rear brackets look like 2010 from what i can see in the pics ... so for the most part it fits both.... just the bucket would be a little big for the 1010 and if you wanted to mount it on a 1010 you would have to find a few brackets.... I wish it was closer I would love to have it for parts my links are a little lose...I also don't want to see it scraped :( :(
Pammark
Post by Pammark » Sat Jan 19, 2013 5:52 pm
The bucket seemed a little smaller than mine. I would guess it is the 3/4 yard bucket. Good for a 1010.
Mark
Post by jtrichard » Sat Jan 19, 2013 6:40 pm
on the 2010 which you have.. they had the standard bucket 1yard and light weight material bucket which is 1 1/2 yard on the 1010 standard was 3/4 yard and light weight material was 1 1/4 yard you might have the 1 1/2 YD bucket.... if you look at your rearmost bracket at the bottom where it bolts to the machine they angle at about a 45 on the 1010 it is straight up and down looks like the one in the pic above is angled but it might just be the hose hanging in the way of seeing the mounting pad ....after looking at more parts pics the top of the rear most brackets are only angled on the 1010 so it just about has to be off of a 1010 that is why the bucket looks smaller than yours
Pammark
Post by Pammark » Mon Jan 21, 2013 9:46 am
I think the bottom of the rear mount is angled. I also think the model is the precurser to my 820. So I agree it looks like a 1010 loader, but might have the conversion kit to mount on the early 2010. The 1010 had a model 810. This is a model 810-820 and mine is the 820 My dozer serial number is the later 2010.
Mark
Pammark
Post by Pammark » Mon Jan 21, 2013 9:47 am
Mark
Post by Tigerhaze » Mon Jan 21, 2013 11:30 am
The nice thing about it is that it has the hoe brackets- seems like they are getting hard to find so would be nice for someone that wants to make their 2010 crawler a hoe crawler.
