1950 mc low power??
1950 mc low power??
Overall my mc is running good. only Issue I got so far is when i put it in 4th it either doesn't move or "lugs" / that is it moves a few feet then stalls out. Any other gear its pretty sweet. pops right along without any issues.
Any ideas????
Any ideas????
1950 mc crawling around
Make sure timing and carb settings are okay first.
- mapaduke@yahoo.com
- gregjo1948
MC low power
Is your governor working OK ? gregjo1948
Sooo farrr
Looking into it, just got the charging system straightened out fully last month. it still lugs/dies in 4th. the gov linkages appear to work smoothly and I have no other problems in any other gear. I gotta remember to bring my compression tester home from work to see what that is. Any ideas of what the cranking/running compression should be for these 'ol girls???
Thanks Alot! keep on crawling....
- DukeofDeere
MC should be in the 110PSI range if good shape I think.
- DukeofDeere
Perhaps worth mentioning... when you do a compression test, make sure there is no obstruction in the intake - choke is off, throttle butterfly fully open. The engine needs to breathe air as freely as possible to get a good compression measurement. Battery should be good and strong. Sometimes I put mine on the charger before the test and also give it a boost between runs. (more of an issue when there are more cylinders and/or an older battery)
Best regards,
Steve O.
1958 440IC w/ blade (602?)
Steve O.
COMPRESSION RESULTS ARE IN
#1 cylinder pops 75psi constantly. #2 however 50 psi
shucks. that i would believe is why i haven't any power in 4th gear.
well, now thats identified, on to the next thing..
Re: COMPRESSION RESULTS ARE IN
Rings or valves? Did you throw some motor oil into the cylinders and repeat the test? (temporarily seals the rings and brings the numbers up IF the problem is rings)monzanick wrote:#1 cylinder pops 75psi constantly. #2 however 50 psi
Best regards,
Steve O.
Steve O.
