Question about non JD crawler
05victorylly
Post by 05victorylly » Tue Dec 25, 2012 11:57 pm
Does anyone know if the case 450 crawlers were wet or dry clutches? The machine I am inquiring about is a track loader with a 4 cylinder diesel with torque converter.
I am wondering if the steering clutches are wet or dry. I was running and working great until my uncle got it stuck in a small stream. I was sunk in over the back of the tracks and stuck there for about two weeks.
It starts and runs but doesn't drive at all. Engine runs well and bucket works fine but delivers zero power to the tracks. I am just trying to understand what could have possibly gone wrong....
IH 500 6-day dozer , JD 2010 track loader, Ford 1900 4x4
scampr
Post by scampr » Wed Dec 26, 2012 12:25 am
not positive but i think its a power system where it puts power to the final drives all the time but lessens the power to let them steer.The name of the system slips me but they dont use conventional clutches and brakes,
scampr 440icd, 350B, 47 Farmall H, 55 Farmall cub and ashamed to have a Kabota too
05victorylly
Post by 05victorylly » Wed Dec 26, 2012 8:49 am
The more I read I am realizing the finals are basically direct drive and controlled hydraulicly with either HI/LO or Neutral to each final drive.
But that makes me even more confused as to what would cause the machine to stop driving completely due to be being stuck in a creek for a few weeks only over the the tracks no higher.
Post by Lavoy » Wed Dec 26, 2012 9:48 am
From what I know, they have a planetary connected to each steering lever and you can shift one track down a gear when you pull back slightly on the steering lever. I think they might be still differential steer or some sort, but can't swear to it.
shinnery
Post by shinnery » Wed Dec 26, 2012 7:16 pm
You might try either the dozer or Case forums on Yesterday's Tractor dot com. There seem to be plenty of people that will help on those two forums. Or if J. DeMaris sees this here I believe he has a Case dozer or two.
