water pump
Sprack
water pump
Post by Sprack » Sun Dec 09, 2012 11:52 am
Looking for a water pump for JD 2010?
Post by jtrichard » Sun Dec 09, 2012 1:15 pm
beware crawler pump is different that wheel tractor i found a place on line The water pump man 1 248 225 0625 that should be able to help you out the bearing/shaft and seal are common parts the impeller is JD only and very pricey if you can get the bearing and seal and have a press its not to hard to rebuild it your self the book tells you how
Post by Tigerhaze » Sun Dec 09, 2012 4:49 pm
I would also suggest checking with Lavoy (site administrator) as he sells parts at prices that are comparable to others even after shipping.
