49-MC HYD LINE
Dave Auger
49-MC HYD LINE
Post by Dave Auger » Sun Nov 25, 2012 6:56 pm
Hello everyone, hope all of you had a great turkey day,
I found out why the hyd sys is slow, the suction side is resricted,someone used a rubber line off the pump, half kinked and at the tank end the nut is tight but line is'nt, should this be a one piese line?
Post by Lavoy » Sun Nov 25, 2012 6:57 pm
Should be a one piece steel line. Nut at the tank is not a bid deal, the suction part of the line should be below the oil level.
Dave Auger
MC HYD LINE
Post by Dave Auger » Wed Nov 28, 2012 1:06 pm
HI, I'm looking for a hyd line for a mc , from the hyd tank to the pump,the parts man. # is key#9--part#m1346t Thank's Dave
boler76
MC hydraulic suction line
Post by boler76 » Wed Nov 28, 2012 4:32 pm
I had same problem, I cut the existing piece of steel and shoved a piece of hydraulic hose over the steel , at the ends and used 2 hose clamps per end, works fine on my MC
Dave Auger
Post by Dave Auger » Fri Nov 30, 2012 5:10 pm
Thank's for the info, I'll check to see how far down in the tank the line is,then piece it together. have great day (if you can)
Users browsing this forum: No registered users and 350 guests
