Loader capacity for 2010 track loader
05victorylly
- 430 crawler
Hey guys, I have been searching for a few days and can't seem to locate any info. Its a 1964 JD 2010 track loader. I'll attach a picture. I am mostly looking to figure out how many yards the bucket holds. But any other specs are much appreciated.
IH 500 6-day dozer , JD 2010 track loader, Ford 1900 4x4
jdemaris
Re: Loader capacity for 2010 track loader
2010 crawler-loader came with a 1 yard front bucket for normal use and a 1 1/2 yard for "light materials " use.05victorylly wrote:Hey guys, I have been searching for a few days and can't seem to locate any info. Its a 1964 JD 2010 track loader. I'll attach a picture. I am mostly looking to figure out how many yards the bucket holds. But any other specs are much appreciated.
I have the operator manual for a 2010 loader. Here are some specs.
Bucket width - 66 1/4"
Bucket vol - 1 cu yd
Bucket lift - 4,500 lbs
Bucket lift height - 115 1/2"
Dump angle up - 50'
Dump angle down - 70'
My 2010 weighed in at 6.5 ton with the bucket and back weights.
I hope this helps.
Mark
Dump angle up - 50'
I hope this helps.
Mark
JD 2010 Crawler with Loader
jdemaris
I don't have all the specs on the 2010 crawler loader. But . . since Deere put almost the same size bucket on it as the 450 crawler-loader, I'm going to assume they are comparible. 2010 came with a "normal use" 1 yard bucket and the 450 came with a "normal use" 1 1/8 yard bucket.05victorylly wrote:Hey guys, I have been searching for a few days and can't seem to locate any info. Its a 1964 JD 2010 track loader.
350 crawler loader with ¾ yard bucket: front bucket breakout-force = 9000 lbs. front bucket carry capacity 3 feet off the ground = no spec given. Front bucket carry capacity at full height = 4000 lbs
450 crawler loader with 1 1/8 yard front bucket: front bucket breakout-force = 12000 lbs. front bucket carry capacity 3 feet off the ground = no spec given. Front bucket carry capacity at full height = 5500 lbs
1010 crawler loader with ¾ yard bucket: front bucket breakout-force = 8500 lbs. front bucket carry capacity 3 feet off the ground = 7900 lbs. Front bucket carry capacity at full height = 4000 lbs
05victorylly
- 430 crawler
jdemaris
As far as the crawler-loader 2010 goes - it's got near the same lifitng capacity as a 450 crawler-loader. Has an engine about inbetween a 350 and 450. 350 uses a 135 gas or a 152/164 diesel. A 450 uses a 180 gas or a 202/219/239 diesel. A 2010 uses a 144 gas or a 165 diesel.05victorylly wrote:Awesome thanks guys! I assumed it was a 1 yard bucket, but I was not sure. So the 2010 is basically in between a 350 and 450 in size and power?...is that correct?
350 replaced the 1010 but utilized some of its design and is heavier. 450 replaced and utilized some of the 2010 design and is also heavier.
This thread has a number of specs for the 2010 crawlers, especially on Page 2.05victorylly wrote: Hey guys, I have been searching for a few days and can't seem to locate any info. Its a 1964 JD 2010 track loader. I'll attach a picture. I am mostly looking to figure out how many yards the bucket holds. But any other specs are much appreciated.
http://www.jdcrawlers.com/messageboard/ ... c&start=15
