just bought my fist mc crawler
Dave Auger
Post by Dave Auger » Wed Nov 07, 2012 6:59 pm
run's great,had to back off the trac sdjuster's ,the man I bought it from just had new pin's & bushing done last year and had not driven it much,so I drove in around a bit and they did not loosing up, started to check up on it ,they had all the spring's cranked up so tight it would not even roll, so I back off quite a bit, how tight shoud they be? thank's Dave .
Post by Lavoy » Wed Nov 07, 2012 8:19 pm
About an inch sag from sprocket to idler. If the tracks sat long enough to have set up some, best way to loosen them up is run in water or snow.
Dave Auger
mc track adjustment
Post by Dave Auger » Wed Nov 07, 2012 9:09 pm
thank you for the info, I think this was a steel for 1500.00, the hyd's are slow, I think the psi is only 600 , it's hard to grade with,he use hyd oil,sould I use motor oil?
Dave Auger
Post by Lavoy » Wed Nov 07, 2012 9:11 pm
Hyd oil is fine, might be bad bearings in pump, or may just need the bypass setup.
Dave Auger
mc
Post by Dave Auger » Wed Nov 07, 2012 9:17 pm
I'm still waiting for the manual, what should the pressure relief be set at?
Willyr
Post by Willyr » Thu Nov 08, 2012 2:51 am
900 psi, anything more and you will wear out your pump. Alas new equipment wont allow anything lower than 1500. So plan to rebuild the pump eventually.
former owner of a 1956 420c
Users browsing this forum: No registered users and 223 guests
