2010 injectors, 2 too big, or 2 too small?
I pulled the injectors from my 2010 to get to the bottom of an issue I had with smoke. The pintle on two of them are at least twice as big as the other two injectors. One of the two bigger ones has a number 20 on the side of the body while none of the others do. Estimating the size across the pin, two are about 1/16, and the other two are about 1/8,(just an estimate). My question is, which is correct? Starting at the radiator, #1&2 are the smaller injectors,and #3&4 are where the larger ones were. Maybe for some reason this is normal, but it seemed wrong to me. I want to replace them all this winter, but for now I can get by. Just looking for some input or answers.
Something is not right, I would take them to a good injection shop and have them checked out. Or, if they are the late style injectors, get rebuilt ones.
I will definatly do that. According to the info I got from the injection manual, they are Bosch, and from the s/n my machine its a '64 if that means they would be late style. I found some online for $155 each with a $100 core. Wont be able to get them for a while but it is at the top of the list. Any idea what the # 20 is or if there is a certain size I need to get?
$155 sounds a little high, I think mine are $125. If your cores are good, then don't worry about the core charge.
Not sure what the 20 would mean.
As long as we are talking about the late style injectors, $125/each is the last price I had on the complete injector ready to bolt in and run.
Nothing that I have. If you have a parts catalog, give me the part number of yours, or send a pic.
That should be them. Shoot me an e-mail if you want me to check on availability, but worst case scenario, I will just send yours in for rebuild.
Users browsing this forum: KPaXz and 198 guests
