Any ideas on where to get a injection pump bench tested and how much it cost????
Thanks,
royboy
Roosa-Master pump bench tested..
- gregjo1948
Roosa-Master bench test
If you don't have a dedicated pump shop, try truck stops,truck dealers, tractor dealers, and etc. . Greg
- Paul Buhler
jdemaris
Re: Roosa-Master pump bench tested..
In any pump shop I worked in - it was standard policy to never mount anyone's pump on the test stand unless we had it apart first (and worked on it). Many consider it too risky to install a pump in unknown condition on a very expensive test bench. It's also takes a bit of labor. Half the time spent in pump repair is mounting on the stand and testing.royboy wrote:Any ideas on where to get a injection pump bench tested and how much it cost????
Thanks,
royboy
Some tests you can do yourself pretty easy. What exactly are you trying to find out? If it's injecting, timing advance?
Users browsing this forum: No registered users and 382 guests
