Finding serial #s on a 1981 JD 350 crawler
WMc
Post by WMc » Sat Oct 06, 2012 1:18 pm
I have pulled the plate off of the crawler located at the lower part of the operator console, Its been sand blasted buy a previous owner and I cant read the #s.
Are there some numbers casted into the engine block like on a car motor?
if so where are they located.
I need to rebuild my injector pump, But I need the serial # to see what injector pump I have. I have pulled the tag off of the injector pump, But its been sand blasted too and I can't read it either.
Any help on how to find the serial # would be great.
Thanks in advance
Walt McDonald
1981 350C JD crawler/1939 Ford 9N
CatD8RII
Post by CatD8RII » Sat Oct 06, 2012 2:42 pm
The engine should have it's own tag above the starter motor on the right side. What makes you believe the machine is a 1981? If its an 81 then its a 350C. On the 350C machines the serial tags are on the front of the battery box, not down near the gearshift like on the straight 350s. Worst case scenario, the transmission case should have the serial number stamped in on its top side all the way in the back under the fuel tank. One side will have the a dimension for setting your ring/pinion and on the other side should be the serial number.
WMc
Post by WMc » Sat Oct 06, 2012 3:42 pm
Thanks for the info.
I'll look for the numbers.
The guy I bought the crawler from told me it was an 81'... I assumed he was rite.
Thanks again
Walt McDonald
CatD8RII
Post by CatD8RII » Sat Oct 06, 2012 8:56 pm
Just an FYI, I got a chance to look at one of my machines today, the serial number should be on the right side of the top of the transmission case.
Let us know what you find
Post by Tigerhaze » Mon Oct 08, 2012 10:59 am
WMc wrote: The guy I bought the crawler from told me it was an 81'... I assumed he was rite.
It is very common for sellers to not only have the year of manufacture wrong but also the model itself. There are some major differences between a straight 350 and a 350C so you will want to be sure.
WMc
Post by WMc » Wed Oct 10, 2012 6:33 pm
I'll look for the numbers this week end and report back.
Thanks for the info and the help.
Walt McDonald
WMc
Post by WMc » Fri Dec 14, 2012 11:25 pm
sorry for the late reply...Divorce takes it out of you...
I found this number 6:408, It looks more like a gear ratio number
I've got some cleaning juice....I'll look a little harder....
Walt McDonald
