6 way blade
rustydeeretech
6 way blade
Post by rustydeeretech » Sun Sep 16, 2012 9:25 pm
i have a power 6 way blade on my 350 and i have noticed when i use the 6th function the blade will go down farther if i lean it to the left side then the right side i know the cylinder is moving full stroke and not binding and the arrows are about 2 inches off from each other when the blade is level i dont really see any thing worn does any one have any ideas thanks
jd 450b loader 450c dozer 350 dozer
Post by jtrichard » Sun Sep 16, 2012 10:58 pm
i don't know if its the same on a 350 but a 2010 has the same basic blade and one side will go lower than then the other thats why they moved the ram to the top center on the later machines
jmanatee
Post by jmanatee » Mon Sep 17, 2012 8:29 pm
my 350b 6way blade goes lower one way then the other. I couldnt tell you which way unless I went outside and fired it up.
