450B Radiator
hodgdon42
450B Radiator
Post by hodgdon42 » Thu Aug 09, 2012 6:14 pm
Anyone know where I can get a new or used radiator for a 450B? I was pushing over some small birch trees and one sprung into the side engine opening while I was backing up. Went threw the fan and punched a good sized hole. Im in Maine.
LeonardL
Post by LeonardL » Thu Aug 09, 2012 7:04 pm
You might check here with Lavoy first. Not sure what all he has. E-Bay is another place to look or you could also "Google" for salvage yards out your way.
Another option is to take your radiator to a good radiator shop and have it re-cored and re-built. It's usually cheaper too. Some of these guys that are out your way may know of a place to pick one up select used.
I'm curious what this did to your fan? I suspect it is in bad shape as well? Just curious.
Post by Tigerhaze » Fri Aug 10, 2012 10:50 am
As Leonard mentioned, you will need to check the condition of the fan. If a blade is bent or cracked, it can fly off later and do further damage or hurt someone when you least expect it.
jsal
Radiator Re Core 350JD dozer
Post by jsal » Thu Nov 15, 2012 8:05 pm
Check out www.detroitrad.com Local shop $475 Detroit rad $355 have
manufacturing shops in different States not just Michigan.
Post by Paul Buhler » Fri Nov 16, 2012 9:22 am
Try these guys. I 've found them helpful and fair. Paul
http://pbhequipment.com/
Post by Lavoy » Fri Nov 16, 2012 10:41 am
I don't have anything that late, and no new ones yet that I have found from my suppliers. Doesn't mean someone doesn't have them though.
Post by digitup2 » Fri Nov 16, 2012 2:03 pm
when pushing over small brush you really have to be on guard .We had a backhoe operator push some brush down and backup as he did he crammed a sapling between the block and the injector pump .Guess which one lost yep I put a new pump on it and core value was 0$ Some 25 years ago I was cleaning up swamp when I heard a scream coming from the neighboring property I was working with a contractor next door we were cleaning up a swamp area I walked over to find the dozer operator pined to his 450D Deere with a sapling under his fuel tank through a small crack in the kick pan under his seat through the heal of his work boot and in his right heal and out by his little toe pushing his foot into the front kick board above the decelerator I never ran so fast for a set of bolt cutters in my life I remember saying this is going to hurt he was going into shock at that point and never remembered me cutting the sapling behind his foot [He doesn't even remember me grinding on that dam sapling with the bolt cutters ]several times we have laughed talking the day over that one happened but I try not to even leave the small stuff behind it can be a killer and always put the fuel tank guard back on after no mater how long it takes there is a reason for it so if you don't have a guard on then get one made PLEASE !!Digitup.
ib4hoyt
Post by ib4hoyt » Fri Nov 16, 2012 9:45 pm
did it go between the holes on the side plate or don't it have them?
Post by digitup2 » Sat Nov 17, 2012 10:35 am
I think the sapling took and parted the the kick plate from the floor plate I know it went right in the middle of the heal at the seam then off the heal of his boot .That was a while ago and I never took his boot off They had that job in the hospital I drove his dozer to my truck and the big job was getting him in the truck at that point! I know I never thought much of the guy till that day and he avoided me as well but after that we had some thing in common at that point and he respected me for some reason to this day when he sees me he stops and talks shop.Digitup.
donerite repair
Post by donerite repair » Fri Dec 14, 2012 10:21 pm
I have one 250 plus shipping from mich call 313 8158369 im parting out one
450 b dozer
350BW dozer
450 Dozer 580d case
560 Insley excuvator
