I am trying to figure out the correct procedure for installing a new top carrier track roller on on a JD 450C. The old roller broke off the shaft, and at this point, the old shaft is what is left, attached to the bracket.
I have purhcased a new part, which includes the roller and shaft all in one piece. I am assuming the shaft is pressed into the bracket; therefore, I will need to remove the bracket holding the old shaft, then have the old shaft pressed out, on the new one pressed in.
Please let me know if this is the correct procedure.
Thanks in advance,
Bob
JD 450C top track roller
Users browsing this forum: No registered users and 329 guests
