bad memory
Eric.MacLeod
bad memory
Post by Eric.MacLeod » Fri Jul 13, 2012 5:07 pm
hello, ive put my 420 on the back burner for so long that i cant remember what these parts where for,18520,,18590,,15123,, and 15245..these are most likley for the rearend, i never could get the quills apart. im hoping that i can get away without having to take those apart because thats why i gave up on it in the first place.. thanks..Eric.
Post by Paul Buhler » Sat Jul 14, 2012 2:53 am
Go to the john Deere web site, enter "420" for model, and down load the PC505 .pdf manual to find part numbers and parts pictures. Good luck. Paul
gus
Re: bad memory
Post by gus » Sat Jul 14, 2012 11:56 am
Eric.MacLeod wrote:hello, ive put my 420 on the back burner for so long that i cant remember what these parts where for,18520,,18590,,15123,, and 15245..these are most likley for the rearend, i never could get the quills apart. im hoping that i can get away without having to take those apart because thats why i gave up on it in the first place.. thanks..Eric.
When I was rebuilding mine, I almost didn't take the quills out either. It would have been a bad mistake. I found all sorts of problems there from worn linkage, no lubrication, bad seals to broken bolts. On Lavoys advise, I looked in EVERYTHING. If I hadn't, I would have been back in there after a few hours of run time.
If you're that far apart...look.
Eric.MacLeod
Post by Eric.MacLeod » Sun Jul 15, 2012 8:13 pm
thanks guys when i looked at the drawings on the deere website i can see where the bearings go,thanks.. now to put this darn thing back together...Eric.
