Injection Pump Rebuild
jsutin_prendergast
Post by jsutin_prendergast » Fri Jun 08, 2012 10:45 pm
I have a 1970 350 dozer, and I am getting the tiny pieces of rubber in the check valve on the pump. I clean it out and the dozer runs great, but then it looses power. I am thinking about pulling the pump off and fixing it myself. Where can I get a manual for the pump, I have the DB pump. Also what other special tools will I need and where can I find those. Is this something I should tackle or pay a shop to do it. I don't like paying other people to do something if I can do it. So any guidance would be great. Thanks.
MarkW
Post by MarkW » Sun Jun 10, 2012 11:25 am
If you are mechanical enough to own a 40 year old dozer, you are definitely mechanical enough to rebuild the pump. Do a search here, there are some well illustrated threads but you should really get a copy of the SM2045 service manual. Also look up my thread on the subject, as I did not wire the advance lever back the first time I installed it so don't make that mistake.
Where is the dozer located? There may be someone local to you.
jsutin_prendergast
Post by jsutin_prendergast » Sun Jun 10, 2012 1:17 pm
Thanks, I live by Superior, Wisconsin. Where is a good place to get the service manual?
MarkW
Post by MarkW » Mon Jun 11, 2012 12:26 am
John Deere has them, but Lavoy (the site owner here) may also have one for sale, send him a PM. You should also call your local library to see if they can get one for you to check out.
Here is the link to the JD page:
https://techpubs.deere.com/products/ProductResults.aspx
It looks like you have to type in "SM2045" into the window.
I also have to say, that while I was googling that title a link came up for the PDF online, though I suspect it is bootleg.
Larry 8N75381
Post by Larry 8N75381 » Fri Jun 22, 2012 1:19 pm
I had to "rebuild" my injector pump on my JD350 in 2009.
You should read these posts;
http://www.jdcrawlers.com/messageboard/ ... ght=#15745
http://www.jdcrawlers.com/messageboard/ ... ght=#18193
http://www.jdcrawlers.com/messageboard/ ... ght=#20879
Be sure to read my reply in this post;
http://www.jdcrawlers.com/messageboard/ ... ght=#20984
Especially the sentence, "When you get the manual, DO NOT follow it for disassembly of the pump BECAUSE they assume you are doing it in a pump shop and can test it after it is back together." You should NOT mess with the high pressure end of the pump! That end is not where you problem is.
BEFORE you remove the pump, mark the location/orientation of the pump with a scratch-all. Then DO NOT turn the engine just be sure the spot marks on the pump shaft and engine drive line up - see third and fourth images. I tried to follow the directions in the service manual and spent three days rotating the engine by hand to try to make the “book” alignment. WON'T do that again!!! Mark the location/alignment, pull it off, fix it, and put it back exactly the way it came off. That is essentially what I did, and the engine fired right up when the fuel got to the injectors - I DID bleed the lines like you are supposed to but didn’t get the results the service manual talked about, so just tightened the lines and let’er rip.
You WILL need a spline wrench which you can get here;
http://www.mgs4u.com/bristol-wrench-spline.htm
Order the S-291-6
The 8th image is of the “bristol wrench” called for in the service manual and a standard “L” bristol wrench. That is what I am using in image MVC-141S (which webshots.com has as #43)
I got the solid steel “governor weight retainer assembly” (part # 29111) and the “gasket kit (DB)” (part # 24371 from Thompson Diesel Inc.
http://thompsondiesel.com/Contact%20Us.htm
Call outside sales.
I don't get on here much - WAY TOO much else needing to be done. But I have a broken track adjuster cylinder. :-(
So, I hope this is in time to help you.
Oliver OC-4 Dozer, '67 Ford 3000, '48 Ford 8N75381, '67 JD 350 Loader
Post by Lavoy » Fri Jun 22, 2012 2:19 pm
I should have a couple of the injection manuals on hand.
DaveP
Post by DaveP » Sun Jun 24, 2012 6:31 pm
I also have the DB pump. Why might the injector pump freeze up? I finally got mine off and it snapped the drive shaft at the narrow section. Any recommendations where I can get a drive shaft? I've looked online and have found pumps, but they apparently don't come with the shaft. Thanks
1966? JD350 crawler dozer SNT4F3D023872T
1967 Kaiser Jeep 5ton dump truck
1966 Cessna 150F
1965 Cessna 150E
WMc
Newbie Injector pump problems w/ 350 crawler
Post by WMc » Sun Jul 08, 2012 12:43 pm
Hello every one;
I am having the same injector pump issues w/ my 1981 350 crawler. It wont rev-up and dies after 5-10 minutes.
I have the part#'s from the forum postings for everything but the steel
gov. weight.
Does anyone have it?
Thanks for such a helpful forum.This is a great find.
Walt McDonald
1981 350C JD crawler/1939 Ford 9N
Larry 8N75381
Post by Larry 8N75381 » Sun Jul 08, 2012 6:52 pm
This should answer your question - you might want to read the rest of my reply so you can get some (I hope) helpful hints.
Larry 8N75381 wrote: I got the solid steel “governor weight retainer assembly” (part # 29111) and the “gasket kit (DB)” (part # 24371 from Thompson Diesel Inc.
Call outside sales.
URL didn't survive inside the quote, so here it is.
WMc
Post by WMc » Mon Jul 09, 2012 5:07 pm
Thanks Larry
I should pay more attention.
P.O.O..."Parts On Order"
Thanks again
Walt McDonald
Users browsing this forum: No registered users and 159 guests
