drain plugs
remley
drain plugs
Post by remley » Thu Jun 07, 2012 3:16 pm
I have a 450c with tank heater I need to know how many drain plugs are in the block. I just finished replacing the fan rad. hoses. Started it up and burst the 5/8 hose tto the coolant heater tank. Took the lowest hose off and some nasty stuff came out, not much but enough that I want to do a flush. I can only find those two block drains tha are piped for the coolant heater. Thanks again,you guys on this forum have helped this old man a lot.
Thanks again!
77 Ford
Post by 77 Ford » Thu Jun 07, 2012 8:20 pm
Those are the only ones my 450c had, in the way of block plugs. If you are changing hoses don't forget the little ellbows that connect to the cooler by the oil filter.
I really recommend buying the correct hoses from Jd. I tried to make mine and they kept kinking... the hoses ellbows are fairly inexpensive.
JD- 450C track loader
Serial #208336T
Users browsing this forum: No registered users and 275 guests
