82 450C
remley
82 450C
Post by remley » Wed May 16, 2012 9:08 am
Hi.
In the woods with my 450C,a branch came up fron the side and bent my fan blades,possibly ruined the rad. and water pump. Can i pull this crawler with the trans. in neut and the loader bucket floating.
Is a water pump,fan.and rad. readily available.
Thanks for the help,I'm off to the woods to try and remove the fn and rad. before I hear from you guys.
oljoe
Post by oljoe » Wed May 16, 2012 12:44 pm
Try Zimmerman Tractor in Versailles, MO. Thay have a lot of used parts and may have what you need.
shinnery
Post by shinnery » Wed May 16, 2012 1:21 pm
It should roll free in neutral.
Re: 82 450C
Post by Tigerhaze » Thu May 17, 2012 9:28 am
tjdub
Re: 82 450C
Post by tjdub » Sat May 19, 2012 8:31 pm
remley wrote:Can i pull this crawler with the trans. in neut
I think there's a "true" neutral between 2 and 3 on the range shifter with HLR transmissions. I remember reading a thread about it here, but can't find it back now.
Re: 82 450C
Post by Tigerhaze » Mon May 21, 2012 11:30 am
On my 2010 (not sure if same on the 450s) there is a "tow" gear on the range selector. The crawler will roll with the HLR in neutral, but it is preferable to also have the range selector in "tow" especially if being towed any distance or at a higher speed.
Users browsing this forum: No registered users and 318 guests
