2010 Track Adjuster partsr
ratty
Post by ratty » Wed May 16, 2012 6:59 am
I am looking for the outer part of a hydraulic track adjuster for a JD 2010. Mine cracked along the length. I had the track quite tight as I was having trouble with the track coming off the left rear sprocket.
Post by Lavoy » Wed May 16, 2012 8:08 am
I might be able to get an aftermarket adjuster, I can check.
Running the track that tight will lead to drastically increased wear, and potential breakage of components.
ratty
Post by ratty » Wed May 16, 2012 1:54 pm
An aftermarket adjuster might be the answer or perhaps go to mechanical adjusters. The root cause of my problem seems to be the track coming off and I thought keeping it tighter was the answer. After I reverse and lock the right track up to turn I think with the track looser I just drive out of the links when I go ahead. If there are adjusters available I would appreciate the information.
Post by Lavoy » Thu May 17, 2012 9:20 am
Mechanical or hyd, there will be no difference in either as far as the track coming off.
I sent you an e-mail yesterday with pricing.
ratty
Post by ratty » Thu May 17, 2012 5:07 pm
I havn't deleted any e-mails and I didn't get the pricing e-mail on the track adjusters. It must have disappeared into the ether.If you could re send it would be appreciated.
Thank you Much
Ratty
Post by Lavoy » Fri May 18, 2012 9:28 am
Done.
