1010 crawler parts needed
1010rookie
Post by 1010rookie » Wed Apr 18, 2012 6:22 pm
looking for the springs that go on the footbrakes, they are on the underside hooked to the pedal and frame. and also what does the lever do on the dash to the far left mine just flops up and down. thanks
whiteclipse16
Post by whiteclipse16 » Thu Apr 19, 2012 5:56 am
If I remember right, the lever on the far left of the dash is the reverser lever.
Ben
cat10til2
Post by cat10til2 » Thu Apr 19, 2012 6:34 am
the lever on the left is the reverser for the tractor. If the lever is working, step on the clutch and pull the lever, the crawler will travel in the opposite direction at the same speed it was going forward.
If the lever is not working, the cable may be broken or just disconnected, If the cable is broken, they are still available through Deere last I looked, but it is over $200. for it.
JD 1010, 610 blade, winch, gas
1968 case 530 CK, 1946 John Deere A, 1928 Ford Doodlebug, 1969 Minneapolis Moline with West forklift attachment
1010rookie
Post by 1010rookie » Thu Apr 19, 2012 10:57 am
thanks i will check into the cable broke
Users browsing this forum: No registered users and 203 guests
