gus
Post
by gus » Wed Apr 11, 2012 4:42 pm
whiteclipse16
Post
by whiteclipse16 » Wed Apr 11, 2012 7:58 pm
Looks great gus. Such a nice job on this build.
Ben
gus
Post
by gus » Tue Apr 17, 2012 2:41 pm
Finally got it on youtube....
This was the first drive. The hydraulics are soft as I was working the air out. I had to remove one cylinder today and have it re sealed by the hyd shop that had just rebuilt it. I haven't put it on yet.
http://youtu.be/h1YpfXnRNjg
gus
Post
by gus » Thu Apr 19, 2012 6:34 pm
I have all the small problems resolved. The hydraulic shop found the problem and fixed the leak. I chased electrical for 2 hours and finally found that the regulator had a short. A new regulator has fixed that. You might have also noted in the video that the right track is tight. These tracks have been sitting for several years (not original to this crawler) and I'm going to run it some to see how much is rust. Once it's been run some, I'll readjust them. I've also made some tracking adjustments. The clutch needs a little adjusting too. It needs to be worked!!
Question??? I special ordered the 6V positive ground regulator (must not have been too special I had it out of stock the next day) and it came with a resistor to put inline on the F terminal. I did and everything works, but why??? Why the resistor?? The regulator is an exact duplicate of the one I had (minus the short
gus
Post
by JD440ICD2006 » Thu Apr 19, 2012 7:26 pm
A resistor limits the amount of electrical current that passes through the circuit.
Think of kinking a garden hose. The kink "resists" the flow of water same as a resistor limits voltage.
Do you need to reduce the voltage past the resistor location in the circuit? If yes, leave it in. If no, you can run without it.
Where is the resistor in the circuit?
whiteclipse16
Post
by whiteclipse16 » Fri Apr 20, 2012 6:40 am
Just to add to what 2006 said. You have to watch terminology here.
If the resistor is in line with F (F wire hooks to one end of resistor then other end of resistor hooks to "F" terminal on regulator (and that's the only connection on "F" terminal)) then it is like a series circuit and will change the Voltage, not the current.
If the F wire AND one end of the resistor are on "F" terminal of regulator and the other end of the resistor is attached to another terminal then it is like a parallel circuit. In this instance it would change the amount of current and the voltage would stay the same.
Sounds like you are adjusting the voltage. It could be that the regulator is a 12 volt regulator and your dropping the voltage down to 6V for the regulator to function properly.
Ben
gus
Post
by gus » Fri Apr 20, 2012 10:47 am
whiteclipse16 wrote:Just to add to what 2006 said. You have to watch terminology here.
It is in line. Drop from 12 to 6??? Nothing 12V in this system. The regulator has a sticker on it that says 6V positive ground. I'm still not sure what it is for and if I ever open the dash again, I might remove it to see what happens. It seems like I'm getting less amps on the guage.
Post
by JD440ICD2006 » Fri Apr 20, 2012 11:43 am
It likely is a universal VR and was on there to cover various applications.
Look in the service and parts book. That would be my guide.
whiteclipse16
Post
by whiteclipse16 » Sat Apr 21, 2012 6:41 am
I'm thinking like 2006. It's universal for 12 or 6 volt and when it got down the assembly line they put a 6 volt sticker on and packed a resistor with it. At least it works good.
Ben
- Site Admin
Post
by Lavoy » Sat Apr 21, 2012 4:11 pm
No resistor needed to go from 12 volt to six, a resistor would be used if it was the other way around. My guess is that it is not a resistor, possibly a diode.
gus
Post
by gus » Sat Apr 21, 2012 4:28 pm
I just looked at the instructions again.
It is a resistor but....my generator is NOT on the list is says to use it with.
I think I'll be removing it.
I think it might be for older tractors that used a cutout or old style regulator. There are diagrams for rewiring them included.
- Site Admin
Post
by Lavoy » Sat Apr 21, 2012 8:12 pm
I would get the correct regulator for your crawler before it wrecks something else, they are readily available, no sense chancing it.
gus
Post
by gus » Sun Apr 22, 2012 11:14 am
The regulator is OK. It's just the resistor kit with it that was different and had a list for older units that mine is not on. My gen is not on the list and is to be used without it. Appearance wise, it is exact with the one that was on it, same size and terminals.
I removed the resistor and it is working fine. No real change on the amp meter and it shows charging as needed.
Question... I have an extra generator and it is missing the small spring which pushes the brush finger down. I think it also holds the finger on at the same time. I will want to clean it up and check it out for future use should I need it. I have 3, all the same, and this one would be the spare.
- Site Admin
Post
by Lavoy » Sun Apr 22, 2012 11:57 am
Must be for some odd application, glad it is working.
gus
Post
by gus » Sun Apr 22, 2012 6:21 pm
