leaking hydraulic hose fitting
rcs110
Post by rcs110 » Sat Apr 07, 2012 11:10 am
would any one know if there is a o ring in the fitting coming from the pump right side as you look at it from front . hose screws into fitting and then fitting is screwed into pump. leaking from where both come together.
have not taken a part yet still wait for service manual to come.
1969 350 crawler
t4e3d
LeonardL
Post by LeonardL » Sat Apr 07, 2012 5:39 pm
So what are you working on dude? What machine? Have you checked to see if the fitting is just loose? You might try to tighten it. But if that isn't it and if I was to guess, it would be a cracked fitting where the two are screwed together. Or someone has over tightened them and messed the mating seats up.
But I need to know what machine you are working on so I'll know what kind of fittings you have. Make sense? :D
rcs110
Post by rcs110 » Sat Apr 07, 2012 6:46 pm
sorry new at this its a 1969 350 crawler its the hydraulic pump right side standing in front of it the leak is coming from where both fitting come together was just wondering if there is a o ring in there.fitting is tight have not taken a part yet , was waiting for service manual to come some time next week. if it is cracked is there a web site that sells them ? thanks
1969 350 crawler
t4e3d
rcs110
Post by rcs110 » Sat Apr 07, 2012 6:48 pm
1969 350 crawler
t4e3d
Post by digitup2 » Sat Apr 07, 2012 7:20 pm
You won't find o rings on older crawlers like that and even the newer o ringed fittings aren't any better than the older stuff It is a snake oil piece of mind sales gimmick as far as leaks go if the fitting is proper and tight it will not need an o ring to seal steel on steel at the proper angle should suffice at 3000 lbs pressure or even 6000 lbs pressure it won't matter what pressure you put on the system if the fitting fits proper make sure you have proper threads on the right fittings this is all it should take .Digitup.
tjdub
Post by tjdub » Sat Apr 07, 2012 8:43 pm
Looks like there is an o-ring there (number 21):
Part Number: U12547
Cost from a John Deere dealer: $1.51
rcs110
Post by rcs110 » Sat Apr 07, 2012 9:05 pm
wow thanks looks the leak is coming from around part 20! I will have to get both of the parts. thanks for the picture of the parts.
1969 350 crawler
t4e3d
Post by digitup2 » Sun Apr 08, 2012 6:39 am
That is in the pump housing and yes it will be an o ring in there any place there is cast housing like that there will an o ring.the problem with those o rings is they get heat from the pump and they crack and go hard so replace that one for sure.Digitup.
LeonardL
Post by LeonardL » Sun Apr 08, 2012 7:05 am
Sorry, let me try this again.... I screwed up.... :oops: The fittings have "Seats" that mate together. They are either damaged as in mashed to the point they are leaking or the pump fitting seat is cracked. If it is leaking at the pump side of the fitting then it can be the o-ring.
rcs110
Post by rcs110 » Sun Apr 08, 2012 8:19 am
is there a on line web site that sells the fittings or do i good to a john deere dealer?
1969 350 crawler
t4e3d
LeonardL
Post by LeonardL » Sun Apr 08, 2012 1:35 pm
I would just go to a Deere dealer and get it. It will come with a new o-ring already installed. And you will have the right fitting and no hassles!... Hopefully! :lol:
rcs110
Post by rcs110 » Sun Apr 08, 2012 2:03 pm
thanks for the info will do that and let you know how i make out with it.
1969 350 crawler
t4e3d
rcs110
Post by rcs110 » Mon Apr 23, 2012 8:00 pm
got the part from john deere $12.95 for the fitting with o ring . going up to my place this weekend to fix the leak, and do some work. and i hope thats it.
1969 350 crawler
t4e3d
Users browsing this forum: No registered users and 443 guests
